Compatibilité axe X mk2.5/mk3
Jerem62
(@jerem62)
Bonjour,
J'ai une mk2.5S. Suite à un changement de roulement, je me suis rendu compte que mon support de poulie sur la pièce imprimée "x-end-idler" s'est arraché et à fendu partiellement la pièce.
Est ce que quelqu'un sait si les pièces de la mk3 est compatible avec la mk2.5s? Faut-il changer le chariot d'extrusion?
Best Answer by JoanTabb:
The Mk3 motor end is not compatible with the Mk2.5 printer as there is no mounting for the X axis Endstop Switch.
the Mk2S printable parts are available on this page
https://www.prusa3d.com/prusa-i3-printable-parts/   The X axis motor end and idler end  are compatible with the Mk2.5S
MK2.5S , MK3S Bear
Projet Voron V0 en cours
Opublikowany : 20/04/2020 11:38 am
RE: Compatibilité axe X mk2.5/mk3
The Mk2.5S uses the same extruder parts as thee Mk3S, with the addition of a buffer for the X Axis Endstop switch.
The Mk3 Extruder parts are not fully  compatible, because the Mk3 uses a different filament sensor.  and it doesn't have an X axis Endstop buffer
If you are desperate you could use the mk3 parts by adding an X axis Endstop switch buffer and turning off the filament sensor facility.  but it would be a bit of messing about
Opublikowany : 20/04/2020 11:56 am
Jerem62
(@jerem62)
@joantabb
Hello & thank you for your answer.
The main issues for me is the x-end-idler and x-end-stepmotor-support parts. Could-I use theses mk3 parts in my mk2.5s?
Perhaps, further, I'll change to mk3 but not now
MK2.5S , MK3S Bear
Opublikowany : 20/04/2020 12:07 pm
Opublikowany : 20/04/2020 3:53 pm
Jerem62
(@jerem62)
I finaly catched the support for the same  answer.
thx
MK2.5S , MK3S Bear
Opublikowany : 20/04/2020 4:05 pm
