What went wrong with this?
RedDawg
(@reddawg)
Printing this trophy and base off of Thingiverse. Printing the STL as posted gives the result on the right. As this result was not large enough, I increased the size by 140%, giving the result shown on the left. The size is right but now all the smooth, rounded contours are "angulated". What caused this and is there a fix? (PrusaSlicer)
Hear ye, Hear ye! Step right up folks and get your Government salvation here! Less than $.002 per word! Amazon.com/dp/B0B8XMMFP4
Opublikowany : 28/07/2023 12:50 am
ntdesign
(@ntdesign)
RE: What went wrong with this?
It would help if you posted a link to the model. I'm guessing it just doesn't have a lot of polygons, and when you enlarge it they show. If that is the case, you should see it in Prusaslicer.
Opublikowany : 28/07/2023 10:19 am
Henry
(@henry-6)
You need to resize it in Blender. Increase the number of triangles and smoothing. Most of the time increasing the size in Prusa works but it does not smooth the print.
Opublikowany : 29/07/2023 3:37 pm
1 ludzie polubili
