Ugly seams on XL
I am printing with 0.32 Quality on XL with 0.6 nozzle, material is PETG, all I got is always this ugly seams no matter what kind of boxes I want to print, is there anything I can do with that?
Opublikowany : 17/12/2023 8:45 am
1 ludzie polubili
That looks nasty. Did you print a heat tower? Perhaps you have to change the temperature a little bit. When I started with my XL I had the impression that it was better for bigger parts as it seemed to be a bit more "rough". Not that it looked that bad. So I swapped to the 0.4 nozzle and it is perfect. It just came to my attention that Prusa is shipping the XL now with the 0.4 nozzle. It is worth a try. When you stick with the 0.6 nozzle you should have a look at the temperature and update your settings.
This post was modified 3 years temu by stephan.ribbrock
Stephan Prusa MK3s+ MMU2S; Prusa XL-1H
Opublikowany : 19/12/2023 10:00 am
