Support makes my 360mm print unprintable on XL - Need help with settings
have a model that's exactly 360mm wide, which technically fits within the XL's build volume. However, when I add supports for an overhang on the side, the total width with supports exceeds the printable area by just a small amount.
Respondido : 03/04/2025 8:44 am
You may be able to design your own custom support: Try a one perimeter thick wall across the outer gap and, if necessary, another on the inside then just poke them out and tidy the edges with a small file post printing.
Respondido : 03/04/2025 12:53 pm
