Printing TPU/TPE on Prusa XL
Página 2 / 2
Gaius Pupus
(@gaius-pupus)
RE: Printing TPU/TPE on Prusa XL
Posted by: @fwiffo
Posted by: @jtresslerimec
Hi, has anyone printed with flexible filament on the XL? There seems to be a lot of resistance on the filament from the PTFE tube. Do I need to bypass the first filament sensor and just run it without a PTFE tube to the extruder? The filament I am using is a 40D TPU with an average diameter of ~1.67 mm.
Any suggestions would be appreciated.
I had to disable as well the filament sensor, since it could stop printing in the middle of a print for not "sensing" the filament in the sensor right above the extruder tube. maybe the elasticity of the filament when it gets pulled is the problem, and as well the sensor not revealing it correctly.
Is that an overture TPU? If yes, I'm using the same, with the amazonbasics tpu settings.
I have noticed that this TPU from Overture smears the nozzles. It takes a long time for the color to be completely flushed out of the nozzle.
Respondido : 20/01/2025 10:38 pm
wldthng842
(@wldthng842)
Posted by: @gaius-pupus
Posted by: @dorkwin
Hi Everybody,
I have to add that I had an issue that keeps occurring. The filament jams in the extruder. By this, I mean that the gear pulls the TPU 95 down from the extruder sensor area, but then pulls it back and away from the hotend / nozzle and into the extruder gear housing. Has anyone experienced something like this?
The friction from the PTFE tubes is too high, the filament is pulled and thinned, and then this happens. That's why Mole Designs hung his spool from the ceiling and I guided the filament over ball bearings.
Has anyone found any solutions for this?  For multi-color prints hanging from the ceiling is less than ideal.
Respondido : 11/05/2025 9:55 am
FStein
(@fstein)
Miembro
Posted by: @wldthng842
Posted by: @dorkwin
Hi Everybody,
I don't have a Solution for this but I do have the same problem at times. I print with Filaflex SEBS. I do not use the bowden tube and feed the filament from the ceiling. For now my only suspicion is that the filament gets squished when it sits too long. Then, it gets wrapped around the extruder gears when extrusion resumes. This is typically the case at the start of a print (during probing etc.)
Once the print started succcessfully, it finishes wihout issues.
If anyone has any ideas what to do about this... I'd be very thankful!
Respondido : 30/06/2025 1:38 pm
Página 2 / 2
