ObXidian Troubles (0.6 mm)
ZeeKay
(@zeekay)
I managed to snag a ObXidian nozzle for my XL and was having underextrusion issues, leading to first layer adhesion problems.  It was acting like a partial clog but nothing was cleaning it. Swapped back to the brass nozzle and same filament and gcode it printed just fine. (Hatchbox PETG/Prusament Galaxy Black PETG)
Went into live chat and was told to increase the flow rate to 120% as the ObXidian has different heat characteristics and it does seem to print exactly like the brass nozzle now. But this seems like a huge increase to the needed flow. Is there an issue with my nozzle or is this pretty much expected? If 120% flow (or maybe more temp?) is needed, I'm not seeing it documented anywhere.
Napsal : 02/09/2023 4:14 am
ZeeKay
(@zeekay)
RE: ObXidian Troubles (0.6 mm)
Well, the 120% got the first layer going, and thus the print with the Galaxy Black. About 15 minutes in there was a glob on the print and suddenly the lines were way over extruded, by I dunno, 20%? I set it back to 100% flow and since then its seemed perfect, so maybe it really was a partial clog. I'd not have expected this with the Galaxy Black. Generally I shy away from glitter filaments for this reason but I'd not have expected these types of issues with all prusa stuff. I really suspect that one roll (out of 3 I currently have) might just be bad and is prone to clogging?
Napsal : 02/09/2023 4:44 am
Racenviper
(@racenviper)
nozzel temp does need an increase. Had to do it on my MK3
Napsal : 05/09/2023 7:39 pm
1 lidem se líbí
INVESTEGATE
(@investegate)
Yea maybe it was a particular clog. I bought long time a go special "eSun cleaning filament", i think its natural nylon. I heat the nozzle to about 260-290 celsius. Then i extruded about 30cm of the cleaning filament. After that i let cool it down to about 60 celsius and i do a cold pull. I don´t need this often, but it really works pretty nice! You get your nozzle absoulutly clean with that method.
Napsal : 06/09/2023 5:37 pm
