High speed for one color, low speed for others
Daniel Ezell
(@daniel-ezell)
I recently purchased a High Flow Obsidian 500 for my 5 tool XL and I want to specify high flow for this tool (and only this tool). Where do I set that up in Prusa Slicer Print Settings?
Napsal : 15/01/2026 10:42 pm
BaconFase
(@baconfase)
RE: High speed for one color, low speed for others
Can't really do that yet. It's one of the hopes that PS 3.0 brings to the table.
But all the speed settings are really just different specific speed limits and not necessarily the set speed it will actually go. So just use the HF print profile so the HF nozzle isn't limited and then rely on the MVS filament setting to slow down specific toolheads.
Napsal : 08/02/2026 6:47 am
Pe3d
 Pe3d
(@pe3d)
You can create a Highspeed Material Profile für each Material you are using.
https://help.prusa3d.com/article/max-volumetric-speed_127176
Keep in mind that the Print settings define the possible max mvs even If you Set it Higher in the Material Profile.
Best would be to Set printers mvs to 0.
And each Material with its specific values through Material Profile. (Petg 13-18, tpu 3.5, pla 25 etc)
This post was modified před 3 weeks 2 times by Pe3d
Napsal : 15/04/2026 10:42 am
