After first 2 layers infill layers dont print
Astro Physicist Guy
(@astro-physicist-guy)
Been printing with my XL without issue for a while. made a simple block shape with a half circle cutout in the top to use as a riser for a window hammock for my cats and the first one printed without issue. when I went to print a second one, after the initial couple of solid wall layers on the bed, once it went to printing infill layers no infill was printing. print "completed" with only the first couple of solid layers and then nothing. the print continued until it was "done" but no filament had been extruded after teh first couple of solid layers on the bed. tried another file with teh same result. unloaded and loaded filament several times with no joy.
If I just tried to print something after the failed attempt, filament would no longer would  extrude at all.  I had to unload & reload the filament to get the first layer of a new print to work but then the same issue would occur.
All Cals showed good and I also tried using the reset button and loading the latest Apr 15th new firmware but the same thing is still occurring
Opublikowany : 21/04/2025 3:28 pm
