Z height too low on textured sheet
Josh
 Josh
(@josh-11)
Utenti
We are running a new XL using PETG on textured sheets. A few prints in and we noticed that the bed had stuck on filament in a super thin layer from the last print. The next print attempted failed because the extruder was skipping. restarted the print, and although it’s printing, the Z height still seems to low as the first layer has multiple blobs and noticeable ridges between the layer lines. Cleaned the nozzle and bed, reset the printer between attempts. Any other suggestions?
Postato : 12/09/2023 2:57 pm
RE: Z height too low on textured sheet
 No suggestions but watching this thread with interest as I have the opposite problem on my XL (and Mk4). Unless I manually adjust live Z during the first layer I tend to have adhesion issues with the textured sheet.
Postato : 12/09/2023 3:56 pm
1 persone hanno apprezzato
User64X
(@user64x)
Saw you on r/PrusaXL.  Weird I replied to that first then came here and saw this.  Anyways.  Print bed bent?
Postato : 12/09/2023 5:55 pm
Josh
 Josh
(@josh-11)
Utenti
Doesn’t seem to be… the prints are acting like the Z height is uniformly too low.
Postato : 12/09/2023 6:06 pm
Josh
 Josh
(@josh-11)
Utenti
After reset, the successive prints were globbing up like the Z was still too low.
Postato : 12/09/2023 6:08 pm
Josh
 Josh
(@josh-11)
Utenti
Probably an obvious solution, but did you make sure the nozzle was cleaned well? Heard that filament on it could affect the sensor.
Postato : 12/09/2023 6:11 pm
