XL Multi - What Firmware Type to select in Prusaslicer ?
[Solved] XL Multi - What Firmware Type to select in Prusaslicer ?
ogiles
(@ogiles)
Just done assembling my XL 2 x tool and currently installing 2.6.1 PrusaSlicer and have gotten to the select "Firmware Type".
The default is currently on "RepRap/Sprinter", (?) which I did not expect, whereas with my Prusa 3sx I knew it was Marlin based.
Tried a couple of searches trying to find what the XL firmware Type is based upon but with no definitive clarity. Could someone take pity on me and tell me what Firmware Type is best for the XL at this time, or point me to where it is documented please?
Cheers,
Owen
Napsal : 30/09/2023 7:01 am
Acht
 Acht
(@acht)
RE: XL Multi - What Firmware Type to select in Prusaslicer ?
Do you mean G-Code Flavor? That would be "Marlin 2". Where do you even find the option "Firmware Type" in Prusaslicer?
Honestly you should use the configuration wizard and just select the XL 2 tool Version.
Napsal : 30/09/2023 9:47 am
1 lidem se líbí
Asus1357
(@asus1357)
Printer Settings
-General-Firmware
-G-code flavor:
Napsal : 30/09/2023 1:33 pm
1 lidem se líbí
