XL Loadcell Test Not Completing
Chmurd
(@chmurd)
Hey everyone, hope you're all doing well. I'm in a bit of an odd situation—I’ve had a Prusa XL dropped into my lap, and I’m running into issues with the startup self-test.
Since I had no idea what had been done to the printer before I got it, I figured it made sense to do a hard reset, which I’ve already done. The self-test now runs through the early stages but gets stuck at the loadcell test. It just sits there on the loadcell screen with no progress. The temperature is holding at 60°C and the screen is flashing orange and white.
From what I’ve heard, the printer was working not too long ago. I’ve already unplugged and replugged the loadcell wire from the Dwarfboard to make sure the connection is solid, but nothing’s changed.
Not sure what to try next—any ideas?
Opublikowany : 29/05/2025 6:30 pm
Are you following the procedure at: https://help.prusa3d.com/guide/6-first-run_456216      ?
Opublikowany : 29/05/2025 7:33 pm
