RE: XL layer issue
Hard to say without 3mf Project File.
Looks Like a feeding Problem at the Moment with the longest layertime.
Check Maximum volumetric Speed of that specific Filament with your printer. Check also: Temp Tower, Filament idler tension, Filament path.
Good luck Printing!
Publié : 06/04/2026 7:11 am
1 personnes ont aimé
Undo the PTFE tube from the extruder and try pulling some filament through manually - with a single toolhead you will be more vulnerable to internal wear and consequent jamming than multi-toolhead users so if excess force is required to pull filament it may be time to replace the tube.
Publié : 06/04/2026 9:41 am
