XL layer issue
Soebygaard
(@soebygaard)
Utenti
XL layer issue
Lately i randomly have an issue with layers  -  the issue is not related to a specific z position - The layers do not bond - Its an PETG - running 250 dgs  - How do i solve
Postato : 11/03/2026 1:34 pm
Pe3d
 Pe3d
(@pe3d)
RE: XL layer issue
Hard to say without 3mf Project File.
Looks Like a feeding Problem at the Moment with the longest layertime.
Check Maximum volumetric Speed of that specific Filament with your printer. Check also: Temp Tower, Filament idler tension, Filament path.
Good luck Printing!
Postato : 06/04/2026 7:11 am
1 persone hanno apprezzato
Undo the PTFE tube from the extruder and try pulling some filament through manually - with a single toolhead you will be more vulnerable to internal wear and consequent jamming than multi-toolhead users so if excess force is required to pull filament it may be time to replace the tube.
Postato : 06/04/2026 9:41 am
