RE: XL layer issue
Hard to say without 3mf Project File.
Looks Like a feeding Problem at the Moment with the longest layertime.
Check Maximum volumetric Speed of that specific Filament with your printer. Check also: Temp Tower, Filament idler tension, Filament path.
Good luck Printing!
Undo the PTFE tube from the extruder and try pulling some filament through manually - with a single toolhead you will be more vulnerable to internal wear and consequent jamming than multi-toolhead users so if excess force is required to pull filament it may be time to replace the tube.
RE: XL layer issue
@Soebygaard Are you still having this problem? Can you please DM me the following info if you are having the problem.
know what firmware version the printer is on?|
Account email address used to purchase the machines.
What Slicer are you using and if Prusa Slicer, which version.
Thanks
Shane (AKA FromPrusa)
