XL hot end wont get past 170 - still brand new
PonyBoy Pop Art
(@ponyboy-pop-art)
I'm confused.  Got my Prusa XL setup, and got literally (3) prints out.  Ran out of filament and had a minor issue with getting it to reload, as it claimed that there was still filament in the sensor.  Left it for a few days, and finally got back to it.  Set it to heat to PLA, and it never gets beyond 170.  It bounces at 169-170 and stays there.  At first I would think that this is a thermistor issue, but literally (3) prints and zero fails.  Why would I have a fail like this already?  I understand when we get into hundreds or thousands of hours of printing, but this!?!
Any clues appreciated.
Respondido : 20/02/2024 10:27 pm
RE: XL hot end wont get past 170 - still brand new
Could it be the Printer settings, Custom Gcode>Start Gcode?
M104 T0 S{((filament_notes[0]=~/.*HT_MBL10.*/) ? (first_layer_temperature[0] - 10) : (filament_type[0] == "PC" or filament_type[0] == "PA") ? (first_layer_temperature[0] - 25) : (filament_type[0] == "FLEX") ? 210 : (filament_type[0]=~/.*PET.*/) ? 175 : 170)} ; set extruder temp for bed levelingM109 T0 R{((filament_notes[0]=~/.*HT_MBL10.*/) ? (first_layer_temperature[0] - 10) : (filament_type[0] == "PC" or filament_type[0] == "PA") ? (first_layer_temperature[0] - 25) : (filament_type[0] == "FLEX") ? 210 : (filament_type[0]=~/.*PET.*/) ? 175 : 170)} ; wait for temp
I believe that translates to Do a two stage heat up.
Heat to 170C, run Mesh Bed levelling,  Then heat to normal first layer temperature and continue...
the Mini has been doing this for years...
Respondido : 21/02/2024 12:10 am
Don't forget you have two sensors per filament - if the end of the filament overcooked during the run-out you might have a string left behind in the nextruder sensor.
Respondido : 21/02/2024 8:15 am
PonyBoy Pop Art
(@ponyboy-pop-art)
Nope.  Not using GCODE.  Just using the Front Display using "PREHEAT PLA"
Respondido : 21/02/2024 4:16 pm
PonyBoy Pop Art
(@ponyboy-pop-art)
I assume that there is a YouTube video or similar on how to check this?  The Nextruder is a new concept to me, and looks like a magic-black-box.
Respondido : 21/02/2024 4:17 pm
https://help.prusa3d.com/article/filament-sensor-mk4-mk3-9-xl_465702
Respondido : 21/02/2024 5:18 pm
