XL fails print fan RPM test after upgrade to 5.1.2
Beef^3
(@beef3)
Upgraded to 5.1.2 and it said to re-run calibration tests.  First test failed print fan RPM test.  I can see both the print fan and hotend fan spin up during the test.  I can feel air blowing out from under the hotend.
Veröffentlicht : 28/12/2023 9:30 pm
StephenB
(@stephenb)
RE: XL fails print fan RPM test after upgrade to 5.1.2
I have the same issue. I updated to 5.1.2 and then started to receive the same 'fan RPM test' failure during the Self Test.
Veröffentlicht : 30/12/2023 7:15 am
Fallon
(@fallon)
Beef^3
(@beef3)
Removing the shroud for the print fan fixed the issue.  Thank you.
Veröffentlicht : 02/01/2024 8:04 pm
EyeZack
(@eyezack)
Mitglied
For others who find this post: I had the same issue (after doing a hotend swap), I attempted the fan test calibration to make sure I didn't mess anything up and the test started failing (yet both fans running/working). Rather than trying to dissemble anything, I took a small portable vacuum and had it running/sucking close to the exhaust port of the failing fan. Ran the check with the vacuum running and it passed the test. ***Disclaimers: some types of fans when ran 'externally' will produce voltage, which might or might not damage any connected circuitry. Attempt this at your own risk. I minimized the chances by not having the vacuum directly coupled to the exhaust shroud and I only started the vacuum after the fan was running (to assist it getting to whatever speed the test wanted).
Veröffentlicht : 21/12/2024 5:44 pm
