Xl extruder stops
Seite 12 / 16
Brian
(@brian-12)
RE: Xl extruder stops
Posted by: @cloud1983
The problem is currently gone. But I can already see the symptoms. (flickering nozzle lighting that gradually increases) that it's only a matter of time before the problem occurs again. And yes, the cable is like yours. It's the same for everyone, because it's standard. Nobody has it tight.
Posted by: @brian-12
To all those who are happy that changing the plug cover has solved their problem. Have fun. Because the problem will return over time. It is only a question of time. I've been through this game 4 times already. It always goes well for a while and then gradually gets worse again.
So you've changed the plug to the new design and still had problems?
Also do you have slack in your plug cord like I've shown in my pictures?
FYI I have not had the issue and have been printing fine for a year now.  Just trying to figure out why some have the problem and some don't.
The LED flickering isn't related.  They all do that.  I think that's just cheap LEDs.
When you assemble the printer you run those cords, so there is no guarantee that there is slack.  That's why I was asking.
You still haven't answered, are you using the new plug design with the screws.
Veröffentlicht : 06/01/2025 3:56 pm
Cloud1983
(@cloud1983)
No they dont. We have 2 XL at work and none of them have any flickering. Its not Normal.
Veröffentlicht : 06/01/2025 4:09 pm
Cloud1983
(@cloud1983)
I strongly suspect that it does, but it is very noticeable that the flickering increases first and is always followed by the extruder stopping. In my Case the flickering was sometimes very strong. Not just a little bit, very strong.
Posted by: @nick-collura
Man I hope I don’t get these problems. You mention about the flickering nozzle lights. I contacted support about that exact issue what seems like a year ago, and they said it’s nothing to worry about and normal. Now it might be connected to this extruder issue? I sure hope not
Veröffentlicht : 06/01/2025 4:10 pm
Cloud1983
(@cloud1983)
Here you can see the flickering AND stopped extruder. After the reconnect etc both was gone for a long while.This intensity is not normal. Especially as many had also reported that the extruder stops only occurred with the flickering nozzles. Just like mine.
flickering and stoped extruder
Veröffentlicht : 06/01/2025 4:15 pm
Brian
(@brian-12)
I've never had the extruder stop and mine all flicker.  So I disagree that they are related.
Veröffentlicht : 06/01/2025 5:28 pm
Cloud1983
(@cloud1983)
Then you've probably been lucky so far. Let's hope it stays that way for you.
Veröffentlicht : 06/01/2025 5:29 pm
Brian
(@brian-12)
I suspect in your case it's flickering because the plug is coming loose.  I'm my case there's something wrong with the LEDs.
Veröffentlicht : 06/01/2025 5:45 pm
EvoDesigns
(@evodesigns)
Mitglied
I'm almost certain the flickering LEDs have nothing to do with the extruder stopping.
I replaced the buddy board and it still flickers but I've been in 50+ hours with no issues. I printed the connector plug just as an extra precaution and still haven't had issues. As another member asked, have you changed the connector plug?
Veröffentlicht : 06/01/2025 5:59 pm
Cloud1983
(@cloud1983)
YES I HAVE.
It has 1000% to do with it. But think what you want. 😘
Veröffentlicht : 07/01/2025 1:42 pm
EvoDesigns
(@evodesigns)
Mitglied
YES I HAVE.
Will do buddy, I'll keep printing with my flickering LED tool head. 🥰
Veröffentlicht : 07/01/2025 2:40 pm
SailorEric
(@sailoreric)
OK, so I printed the new dwarf cover and plug cover. There was a little hand fitting with a needle file for the best fit. Printed a few hours, so far so good. Even the LED lights have stopped flickering. At the moment all is good. Now if it will just stay that way...
Veröffentlicht : 07/01/2025 8:48 pm
Cloud1983
(@cloud1983)
https://help.prusa3d.com/article/extruder-error-17536-xl_822367
https://github.com/prusa3d/Prusa-Firmware-Buddy/releases/tag/v6.2.0-RC1
Veröffentlicht : 09/01/2025 5:45 pm
Gik
 Gik
(@gik)
You were faster. xD
Thanks!
The long-promised FW has finally arrived and the error has also been mentioned.
An apology is also included. I didn't expect that.
Veröffentlicht : 09/01/2025 5:51 pm
Cloud1983
(@cloud1983)
Interesting though that they write that the plug is held too tight and not that it is too loose. This means that the plug mod would have exactly the opposite effect.
Posted by: @gik
You were faster. xD
Thanks!
Veröffentlicht : 09/01/2025 5:55 pm
LSV
 LSV
(@lsv)
Mitglied
Huh, I was actually wondering about a mod for the cover that increases the space for the connector but still grips the wires and locks them in place. That way the connector is free to be in the best position and the wires don't pull on it
Veröffentlicht : 09/01/2025 6:04 pm
Brian
(@brian-12)
Posted by: @gik
You were faster. xD
Thanks!
I'm not sure, but there half a dozen on the forum so far that this plug mod has completely solved their issue.
The plug being tight is probably the fit between the dwarf case and the plug cover maybe not allowing it to plug in all the way, thus leading to a poor connection.
Veröffentlicht : 09/01/2025 6:08 pm
Cloud1983
(@cloud1983)
Remove the 'dwarf-cover-connector'
Remove the dwarf-cover-connector, as it might hold the cable and its connector too firmly. Fully loosen the bolt that holds the part, and remove the bolt. The dwarf-cover-connector can then be spaced out more, and removed from the Nextruder assembly.
Cloud1983
(@cloud1983)
not half a dozen for sure ;). And reconnect also solved the problem for me for the time being. It remains to be seen whether it will really go away for those who have the mod. it does indeed take a long time for the error to reappear. Sometimes up to 100+ printing hours. And I don't think anyone has been using the mod for that long
Posted by: @gik
You were faster. xD
Thanks!
Veröffentlicht : 09/01/2025 6:18 pm
Brian
(@brian-12)
Posted by: @gik
You were faster. xD
Thanks!
Not half a dozen..... There's 6 people in this thread on the last 2 pages... And the other thread your posting on had at least 2 that I can think of without even going back to look.
You do realize there are multiple different threads on this and your posting on 2 of them, so the number is probably much more than that
I'm not sure where your skepticism comes from, or if it's intentional, but you appear to enjoy casting doubt and negativity.
I guess do whatever brings you enjoyment, but it doesn't help the situation at all.
Good luck.
Veröffentlicht : 09/01/2025 6:46 pm
Cloud1983
(@cloud1983)
you are really funny. 🤣 Your post just amused me a lot. Thank you for it. 🤩 🤣 🤣
Posted by: @gik
You were faster. xD
Thanks!
Good luck.
Veröffentlicht : 09/01/2025 6:48 pm
Seite 12 / 16
