Why am I seeing layers opposite to expected?
Fred Johnston
(@fred-johnston)
Why do i seem to view layers in reverse? (Layer 1 shows whole object, top layer shows only 1 (top) layer... isn't it supposed to show opposite? (layer 1 only one layer, then up one, show 2 layers, etx ???)
Opublikowany : 31/10/2023 4:06 am
BaconFase
(@baconfase)
RE: Why am I seeing layers opposite to expected?
You can drag both the top and/or bottom orange triangle slider to modify the sliced view. In your case your dragging the bottom. Sounds like you're wanting to drag the top one instead.
Opublikowany : 31/10/2023 6:48 am
1 ludzie polubili
What @BaconFase said. Plus, you can click on the pad lock icon below the slider and then drag only one layer at a time.
Opublikowany : 31/10/2023 11:53 am
1 ludzie polubili
Fred Johnston
(@fred-johnston)
Thanks to you both!
Those were both things i learned!
(And that insideous tiny horizontal line I had totally missed too!)
(Screenshot attached...)
Opublikowany : 31/10/2023 2:33 pm
