Tiny grub screw found on print bed?
EG3Dprinting
(@eg3dprinting)
I just noticed this screw on my print bed when I went to remove the print. It's about 4mm long and 3mm in diameter.  I have to assume it's from the extruder assembly, but I can't seem to find where. Anyone know where this might have come from?
Screw
Opublikowany : 11/07/2023 9:55 pm
RE: Tiny grub screw found on print bed?
Thermistor screw?
Opublikowany : 12/07/2023 5:12 pm
EG3Dprinting
(@eg3dprinting)
Ah, yup good call. Top right was the one that came out, must have not been tightened enough from the factory.
Opublikowany : 12/07/2023 5:21 pm
Hello
(@hello)
Could of come loose in shipping
Opublikowany : 12/07/2023 9:04 pm
Racenviper
(@racenviper)
are those t-6 torx?
Opublikowany : 27/07/2023 2:38 am
Pixel
(@pixel)
Posted by: @racenviper
are those t-6 torx?
yes they are TR6
i just installed some heaters and thermistors in spare heater blocks and the TR6 fits perfectly
Opublikowany : 28/07/2023 12:54 pm
Mrbchambers
(@mrbchambers)
I know this is a over a year late, I really appreciate this post however old it is, because I have jus found a grub screw on my print bed, and its the same "Top right was the one that came out". Save me some time searching.
Thanks you.
Opublikowany : 01/09/2024 9:32 pm
