Repeated Failed Prints! Extruder not pulling through filament.
eleven_dymensions
(@eleven_dymensions)
Utenti
Dear Prusa Team,
I am having extreme difficulty geting my XL printer to print!
I have a print which I've attempted around 10 times now,
Currently, it begins to print for sometimes 10 minutes, other times a few hours before it inevitably comes to a halt.
After some investigations, I think the reason for this is it gets to a point where the extruder is no longer pulling the filament through.
The print continues, and 100% is shown on the screen, but the print is only partially done. Very annoying when I left it overnight! Sometimes, I have been there at the point where it's stopped, and I have simply paused it for a minute and resumed. I have also 'changed the filament' by removing it and re inserting it with the end snipped off. Both mean the print has continued for a while longer.
I have tried to diagnose this issue by browsing the various forums and can't seem to find an appropriate solution.
Some things that came to mind:
- Nozzle Wear (prints well sometimes)
- Changed filament reel (potentially faulty batch)
- Clean the hotbed (looked like it didn't stick as it stopped printing during first layer)
- Tension/blockage in first sensor (put piece of filament into it and de-attached pipe, removing sensor from equation)
Last thing to do is to replace the gold wheel or the bearing attached to the clasp which pushes the filament against the wheel.
Is this wise/possible/simple?
Thanks,
Frustrated Owner of XL Printer
Postato : 13/03/2025 4:44 pm
Jawaswag
(@jawaswag)
RE: Repeated Failed Prints! Extruder not pulling through filament.
Does the extruder stop turning or has the filament been stripped? What filament were you using?
My issue from the past was that I was printing PLA Silk, which expands slightly when heated, building pressure in the nozzle until the extruder finally strips the filament. The solution was to reduce the extrusion multiplier to 0.97.
Postato : 20/04/2025 2:21 pm
Shuttlesworth
(@shuttlesworth)
Utenti
Has there been a resolution to this? I am having the same issues after flashing to 6.2.5+8912. My error happens in two ways, one of which the OP describes.
1. The nozzle stops extruding, but continues all tool paths. I did not check to see if the filament was ground down from the extruder gear, but when I started the next print, everything worked as expected.
2. The toolpath stops, as well as the extruder, and I am left with the nozzle stuck in the unfinished print. All while the printer thinks it is continuing the print and I get a notification that the print is complete through PrusaConnect and the screen shows 100%.
I will try reverting to the previous firmware, but that was causing me to get "Extruder not spinning" errors which was fixed in 6.2.5+8912. Any other help would be nice.
Postato : 08/05/2025 11:39 am
Shuttlesworth
(@shuttlesworth)
Utenti
Follow up on reverting firmware, I received "extruder not spinning" error twice, so I will have to go back to the latest firmware.
Postato : 08/05/2025 5:17 pm
Fishy177
(@fishy177)
Utenti
For some background, I have had three different filaments fail on different extruders (Prusament PLA, PC-ABS, and Sunlu TPU), so I know it's not the filament or extruder specifically. The odd part is that I didn't change the PC-ABS filament after the print failed, I just reprinted and it worked (this was also the shortest of the prints, 5hours). I have come to the conclusion that it is sometimes not gripping the filament like you guys said. It has happened twice on overnight prints, one with Prusament PLA, and another with Sunlu TPU, which is already a pain just to even load. I am receiving no error messages and it shows 100% completion just like most others in this forum have said. I don't see how the printer either doesn't have a sensor to detect the filament not being gripped, or it does have one and it simply doesn't work. Very frustrating. Please let me know if anyone finds a solution.
Postato : 31/07/2025 3:08 pm
J-Plasted
(@j-plasted)
you will want to install the new cable strain relief top for the Nextruder, its been proved that the original ones cause movement and stress within the cable bundle at the connector causing higher resistance and then failure. worst case you need a new cable bundle and the new connection, its now a screw down connection and i highly recommend you changing it
Postato : 04/08/2025 11:58 am
Fishy177
(@fishy177)
Utenti
Were these for printers before June of last year? We ordered ours in May of this year (2025), and I remember we got sent new 3D printed pieces with it but did not need to use them since we ordered our printer after the fix took place
Questo post è stato modificato 7 months fa da Fishy177
Postato : 04/08/2025 1:48 pm
J-Plasted
(@j-plasted)
on your printer where the wire connects to the nextruder, is there a screw holding the black plastic down to the nextruder just above the white connector ?
Postato : 04/08/2025 3:13 pm
Fishy177
(@fishy177)
Utenti
I believe so yes. You're referring to the main wire connecting from the nextruder to the buddy board right?
Postato : 04/08/2025 6:25 pm
