Printer pauses for a few seconds mid-print
Erik
 Erik
(@erik-3)
I've been having this problem since I got my 5T XL. The printer will be doing its thing, and then it will just pause for a few moments. While it does that, the filament oozes enough to leave a large zit, then when it resumes it leaves a void because there is no filament in the nozzle. I'm on the latest 6.2.6 firmware now. It isn't every print, and it isn't all 5 tool heads, but I have confirmed it happens on at least two of them. I've replaced the default USB stick with two different ones (an older one I had lying around, and a new one I purchased just for the XL). It doesn't happen in the same place twice, even with the same gcode, and the extruder MOTOR isn't what stops - the entire printer pauses. Has anyone else experienced this?
Questa discussione è stata modificata 7 months fa da Erik
Postato : 16/10/2025 10:26 pm
Is the printer in a draft?  I have seen this once and I believe it coincided with the opening of two doors causing a sudden air change; I assumed something lost heat and the machine paused until temperatures stabilised.  ICBW.
Postato : 16/10/2025 10:36 pm
Erik
 Erik
(@erik-3)
RE: Printer pauses for a few seconds mid-print
I have the printer enclosure, and haven't noticed any wild fluctuations in temperatures. But maybe this is part of the heatbed temperature fluctuations mentioned in FW 6.2.6?
Postato : 16/10/2025 10:40 pm
Hmmmm... Put the temperatures on the LCD screen and next time it happens check them, especially the ones for the current and next toolhead.
Postato : 16/10/2025 10:47 pm
Erik
 Erik
(@erik-3)
It happens once maybe every 10 hours of printing... I don't know that I want to be watching that long. But I do have a camera and Home Assistant monitoring it, so I may be able to track down a pause at some point.
Postato : 16/10/2025 11:32 pm
