Nozzle size doesn't match printer warning when using Prusa Connect
Roger
(@roger-3)
I've started getting this nozzle size mismatch warning every time I post a file to the printer. However, I've checked the printer and the size definitely matches what's set in the slicer.
Has anyone else seen this bug? The print comes out just fine, because the nozzles sizes do in fact match.
Napsal : 26/09/2024 8:36 pm
3D Adventure Printing
(@3d-adventure-printing)
RE: Nozzle size doesn't match printer warning when using Prusa Connect
I've been getting this warning recently as well. No issues printing though. Same as you. Unsure how to fix it.
Napsal : 27/09/2024 5:27 am
NotSwedishBacon
(@notswedishbacon)
https://github.com/prusa3d/Prusa-Firmware-Buddy/releases/tag/v6.2.0-alpha1 its a new feature coming soon. It looks like you can flash the alpha to address this
Napsal : 29/09/2024 5:34 pm
Roger
(@roger-3)
Ok, thanks for that. It's just a waste of everyone's time, releasing something like that into the wild before it's been debugged.
Napsal : 29/09/2024 6:25 pm
