How to change the perimeter speed on one specific layer after M601
SPTNQ.com
(@sptnq-com)
Hi there
I am having a problem. Created a part that has a stop programmed to insert a metal piece. Afterwards, the print continues. The problem I am having is when the printer starts again, the speed for this layer is too fast because the pressure in the nozzle is just not at the max. I only have this issue when printing it in PETG with 0,1mm profile. I think it will help to program '{if layer_num==0}' and adjusting the speed on the perimeter for this line until the nozzle is ready for speed again. Does anybody knows how this works with the perimeter speed adjustment?
Publié : 01/02/2024 3:34 pm
ntdesign
(@ntdesign)
RE: How to change the perimeter speed on one specific layer after M601
That's relatively easy to do.
Right-click on part -> Height Range Modifier. Then on the parts list on the right it will appear under "Layers". You can edit the modifier there to affect the layer(s) in question. Right click on Range (x-y mm) -> Add Settings -> Speed and choose e.g. Perimeters.
Publié : 06/02/2024 8:21 am
SPTNQ.com
(@sptnq-com)
Awesome! Thanks a lot. I never thought about controlling speeds with modifiers. Thanks for the hint!
Publié : 08/02/2024 8:03 am
