Having to manually change nozzle temp?
Generated gcode for a part in Prusa PETG and checked nozzle and bed temps were correct - 230 first layer and 240 for nozzle and 85 for bed. Put the USB stick in the XL and the display says nozzle temp is 170 even though it also says the material is PETG so I have to manually adjust the temp up to 240. Is this right? I thought the gcode would have all the settings for temp etc.
Postato : 08/08/2023 11:54 am
RE: Having to manually change nozzle temp?
170 is the common preheat no ooze warmup temp. If you had left it, it would in all likelyhood changed to the filament print temp.
Postato : 08/08/2023 2:32 pm
Topic starter
answered:
Thanks. Chasing a few issues with PETG and I'm sure it didn't change on one of the prints but checked it again with both PLA and PETG and its changing to the correct nozzle temps. Must have been having a funny 5 minutes.
Postato : 08/08/2023 5:55 pm
