Extra purge on filament change
TJH
 TJH
(@tjh)
My XL has been working smoothly and I just ran out of my first spool.
The filament change works as expected, but the XL still has the annoying feature where it squirts out a bit of filament just before it moves over to start printing again.
With the MK3/MK4, you can usually grab it in time to avoid getting it entrained in the print, but it's a bit harder on the XL.
Anyone know why it does this? It's super annoying.
Opublikowany : 10/10/2023 3:11 pm
Cipis
(@cipis)
RE: Extra purge on filament change
It needs to be there to be sure that the nozzle is pressurized before returning to the print. There will be always some delay/oozing between purging the new color and confirming the change from the user side.
Opublikowany : 11/10/2023 7:12 pm
Chad Walters
(@chad-walters)
Makes sense, but then I think the firmware needs to do a "clean up" step where it wipes this down.. Any way we can do this without a firmware update?
Opublikowany : 17/10/2023 8:01 pm
