Choosing filament on the printer
I print a lot of the same things and would like to use the multi-material aspect of my tool changers to set up several colors and then run the same object through them. Is there any way at the XL (I know how to do this in Slicer) to change the filament selection from tool head 1 to 2?
Veröffentlicht : 20/10/2024 6:19 am
RE: Choosing filament on the printer
When you start a print using the printer's UI, scroll the wheel left on the filament screen to select the filament on the left side. Click it, then select the filament from the right side and select "Replace." Instead of the assigned tool, it'll use the one you selected to replace it.
Veröffentlicht : 19/12/2024 8:51 pm
