Bed levelling fails, nozzle crashing and scraping satin sheet. Z Axis calibration fails.
[Solved] Bed levelling fails, nozzle crashing and scraping satin sheet. Z Axis calibration fails.
tonyk
(@tonyk)
So I tried to swap the factory 0.6 nozzle against a .4. It got stuck, and after a brief chat with support I received a replacement heatsink and swapped it. Printed two benchies. Printer seemed fine.
A while later, I tried to print a bunch of parts that covered most of the satin sheet. Attempted the print three times and then aborted, since the printer was trying to understand the curvature of the print bed for the better part of an hour, and failed each time with a bed levelling error.
It was only after the failed levelling attempts that I noticed scratching or abrasion on the satin sheet, see pictures. It must have started during at least one of the two test benchies, since the there's a large area following the benches bottom. There are also some tiny marks that look like nozzle cleaning. There was at least one failed nozzle cleaning attempt in the mix.
I checked the lead screw bearings. Seemed fine. Lubricated the lead screws. No change.
There seems to be no debris between heated bed and satin sheet. Checked multiple times, both bed and sheet.
Then I re-ran the Z-axis calibration. Interestingly, this failed, but without reason or QR code to follow up. During calibration the bed seems to travel further down than is possible to move with the manual controls (375mm vs 370mm).
I did upgrade to the latest firmware at the same time of the latest attempts, 6.1.3.
How do I continue from here, apart from getting in touch with Support?
Posted : 17/11/2024 3:19 pm
tonyk
(@tonyk)
RE: Bed levelling fails, nozzle crashing and scraping satin sheet. Z Axis calibration fails.
Update:
  • made a mistake before: it's the Z-Axis Self Test that fails, NOT the Z-Axis Calibration
  • spent a few hours with support and tried a bunch of things. Printer worked for a while after swapping to another 0.4 nozzle, but still don't know why. Made it through two prints: a 60min print of the two Z-Axis Bearing Housings in PETG, and a 11h PLA print of my own design. The PLA print previously failed, and used a significant area of the build plate.
  • printer eventually stopped working again. Can't clean nozzle, still scratching build plate during cleaning and calibration
  • I removed and reseated the nozzle multiple times, in order to insert it as much as possible and ensure proper fit, but to no avail
Posted : 22/11/2024 11:25 am
tonyk
(@tonyk)
Fixed! Received another replacement heatsink. Printer works as intended now.
One thing: when swapping in the second replacement, I noticed that the screws holding the heatsink to the mounting plate (and therefore to the main carriage) were loose. I don't remember loosening them during disassembly, which could mean that I didn't properly assemble the extruder after the first heatsink swap. I'm not 100% sure this is what happened due to being distracted during disassembly, but I guess it could explain the erratic behaviour after the first heatsink swap.
In any case, it works now! Z-Axis calibration worked on first try after the swap. Nozzle cleanings are quick and flawless. Printer is on its third full-plate print, and everything is looking great again.
Posted : 05/01/2025 10:58 am
