Way too long, too little info
martinkh
(@martinkh)
Forgive me if I missed it elsewhere, but do we know how the volumetric deposition rate will be different (faster) than the Mini or the MkIII? Can Prusa, in the entry to Q3, at least let us know some performance characteristics? Is Prusa using these in their factory making Printer Parts to help debug it, and how fast is it? Can you show us parts made on the XL vs parts made on other Prusa machines?
Opublikowany : 04/07/2022 2:43 pm
RE: Way too long, too little info
I doubt this has been released and expect it probably will not be shown until the XL is released to testers.
Posted by: @martinkh
Opublikowany : 04/07/2022 4:12 pm
Don't expect much difference with the same-size nozzle, perhaps a small increase.  It will support larger nozzles, some of the additional power supply capacity is to increase melt-speeds.
how fast is it?
I think you are misunderstanding the whole point of the machine.
The example prints at TCT 3Sixty were indistinguishable from those produced on a Mk3 - except no Mk3 can produce parts that big.
Opublikowany : 04/07/2022 5:15 pm
TeachThePrints
(@teachtheprints)
Posted by: @diem
Really? Even the change from 8bit to 32bit doesnt lead to a change in surface quality?
Prusa Mini FW4.4.1
Opublikowany : 20/07/2022 11:03 am
No, why would you expect any deterioration?
Opublikowany : 20/07/2022 1:52 pm
All of the example prints had similar print quality.
Opublikowany : 20/07/2022 2:34 pm
