Framing an area of the print object that you want solid, no infil.
keckenroth
(@keckenroth)
I have the Prusa XL. And I have an object that I would like to select or frame an area that I want to be solid, no infil. I need the added strength in this area. The tool they have for creating support enforcers would work great if they were made to frame an area for no infil.
Postato : 25/03/2024 2:45 pm
RE: Framing an area of the print object that you want solid, no infil.
Try adding a modifier for the area you wish to be stronger, and instead of specifying 100% infill, specify lots of top layers and bottom layers.
the reason for this is, that 100% infill often causes extrusion issues, where as top and bottom layers are less likely to do so...
If I ever want a solid model, I use top and bottom layers
As you might have noticed 100% infill is barred in most infill patterns, simply because it is so problematic
regards  Joan
p.s. I say that top and bottom layers are less likely to cause problems...  because, IF you are having extrusion issues (Leading to filament pickup on the nozzle) which I believe you reported in a different thread,  you may be suffering from over extrusion (Or warped print)
PETG tends to stick to the nozzle when the nozzle is ploughing through existing filament and after a while the filament forms a big enough blob to fall off / wipe off the nozzle, causing issues and possibly layer shifts or models being knocked off the build plate... (this is particularly common with 100%infill, or solid sections of models... )
reducing the flow rate, if you notice a nozzle ploughing through the previous layer, or reducing the extrusion multiplier a little during slicing can reduce the chances  of this happening.
Postato : 25/03/2024 4:07 pm
1 persone hanno apprezzato
keckenroth
(@keckenroth)
I added a modifier and it worked perfectly. I am still getting familiar with the tools available to me.
Thank you.
Postato : 26/03/2024 7:56 pm
You can learn something new, every day!
Lol
Postato : 26/03/2024 9:56 pm
