6.4.0 Firmware for Prusa XL
Jan Kratochvíl
(@jan-kratochvil)
Membre Admin
Summary
  • New features
    • Automatic chamber vent opening/closing (C1/+)
    • Belt tuning wizard (C1/+)
    • Faster and more responsive Prusa Connect experience
    • Nozzle cleaning failed wizard
    • Auto-retract (MK4 family, XL)
    • Auto-retract improvements (C1/+)
    • Auto-retract disable option (C1/+)
    • Selective factory reset
    • Chamber support for backwards G-Code compatibility (C1/+)
  • Changes and improvements
    • Improved print status messages
    • Lazier homing, more cautious calibration
    • Autoload improvements
    • Unified XL & CORE One chamber filtration
    • Option to continue after nozzle cleaning failure
    • Print sheet detection (MK4 family)
    • Respect maximum printed Z position
    • Gearbox alignment calibration (XL)
    • Filament change from Tune menu in any tool (XL)
    • Support cancelling more objects
    • Wi-Fi signal strength indicator
    • BSOD knob press behavior
    • Reworked filament sensor evaluation
    • Ukrainian language support for all printers
  • Fixes
    • All the fixes from the 6.3.X releases have been expanded to other printers.
    • Various fixes and stability improvements
This is the stable release of firmware 6.4.0 for the CORE One+, CORE One, MK4S, MK4, MK3.9S, MK3.9, MK3.5S, MK3.5, MINI, and XL. It reunifies the firmware development branch after the temporary split during the CORE One launch, where 6.3.x was released exclusively for CORE One and other printers remained on 6.2.x. – along with bringing new features, quality-of-life improvements, and fixes across all platforms.
The automatic chamber vent mechanism introduced with the CORE One L is now also available on the CORE One. After updating, the feature can be enabled via Settings → Hardware → Chamber Vent Control by selecting the Auto option.
Manual mode is also available, which keeps the vents closed by default and only shows an informational reminder before each print.
Vents can be controlled manually using the new M870 G-code ("M870 O" = open, "M870 C" = close), although we do not recommend including these commands in slicer profiles, as the printer handles vent control automatically.
The printed parts required to retrofit this feature on existing CORE One printers will be published on Printables in the coming days. A link will be added here once available.
A new guided wizard has been added to the Prusa CORE One to help users properly tension the X/Y belts. The printer uses controlled belt excitation combined with stroboscopic feedback to visualize belt resonance, making the tuning process more intuitive and reliable.
The wizard, accessible via Settings → Manual Belt Tuning, begins by prompting the user to check that the gantry is properly aligned, as misalignment can affect measurement accuracy. A quick manual alignment can be done by loosening both tensioner bolts, gently straightening the gantry by hand, and re-tightening the bolts evenly while keeping the gantry square. More information about gantry alignment can be found in this article.
The wizard then measures the vibration frequency of both belts and recommends whether to tighten or loosen them. The target frequencies are 96 Hz for the upper belt and 92 Hz for the lower belt.
Important: Always tighten both tensioner bolts evenly and alternately. This ensures that the gantry stays square during adjustment.
NOTE: A difference of up to 8 Hz between the belts is acceptable, as long as both values remain within the 90–98 Hz range. If values cannot be reached, the wizard will suggest manual squaring before continuing.
If your gantry is out of alignment, you may not be able to reach these exact values. In some cases, the lower belt can even show a slightly higher frequency than the upper belt.
Communication between the printer and Prusa Connect is now handled using WebSockets, replacing the previous polling-based method.
While this change does not affect raw data transfer speed, it significantly improves overall responsiveness and interaction with the cloud service. Users can expect (via Prusa Connect):
  • Lower latency when starting prints
  • Faster execution of remote commands
  • Smoother and more fluid control during cloud-based workflows
This update also lays the groundwork for future enhancements to remote monitoring and control by the user, allowing for continued improvements to the connected experience in future releases.
The recovery process for failed nozzle cleaning has been reworked into a new step-by-step wizard.
The wizard also includes a filament retraction step to prevent oozing before retrying the automatic cleaning sequence, increasing the chance of successful recovery.
The auto-retract feature is now enabled on MK4 and XL printers, after its first introduction on CORE One in firmware 6.3.X. Filament is automatically retracted from the nozzle at the end of each print, which helps reduce oozing during bed leveling and removes the need to preheat the nozzle when unloading.
NOTE: Auto-retraction is not applied to flexible filaments; to handle these, we have added a new “Is flexible” parameter, configurable in filament presets via the printer’s GUI or using the M865 G-code.
The auto-retract system has been improved across the board, with particularly noticeable benefits for multi-tool prints on the XL. It now respects slicer-issued retractions and avoids adding redundant movements.
On the MK4, the print head now parks at a higher Z-height after print completion to make it easier to remove any ooze left by the auto-retract ramming process.
Auto-retract can now be disabled globally in the Settings menu, although this is not recommended for standard use.
It is also possible to disable auto-retract per filament type. In the filament detail menu, the former "Flexible" option has been renamed to "Auto Retract", with its behavior adjusted accordingly.
We have introduced more granular control over the factory reset process. Instead of wiping all data at once, settings are now divided into categories, allowing you to decide what to reset and what to keep. These categories include:
  • Calibrations: All the calibrations data and selftest results
  • Common misconfigurations: Quirky settings that might cause unexpected behavior if you don’t know about them, for example disabling filament sensors, changing steps per mm
  • Network: Wi-Fi, Ethernet, Prusa Connect, PrusaLink related items
  • User interface: Items that affect user interaction with the printer – language, sound settings, footer settings, touchscreen, LEDs, and so on
  • Stats: Print & error statistics
  • HW configuration: Items that are linked to the hardware installed on the printer: nozzle diameters, extruder type, (also) steps per mm, printer type,...
  • Printer functions: Configuration of various print functions, such as MMU, chamber filtration, HW checks,...
  • User profiles: Custom filaments, print sheets (MINI and MK3.5)
To simplify the process, we have also prepared several reset presets for the most common scenarios:
  • Ownership transfer: Useful when you’re giving the printer to someone else. Will reset all your personal settings such like network and filament profiles, but keep things like hardware configuration, calibrations and statistics.
  • Fix common misconfigurations: This is what the support team will likely advise you to do during troubleshooting. Intended to fix things like filament sensor not working because it was accidentally turned off from the menu.
  • Keep HW config: Keeps only the hardware configuration (what nozzles, fans, extruders the printer has), nothing else. This reset is performed before shipping assembled units to the customers.
  • Full reset: Wipes everything, except for the firmware itself
  • Hard reset: Wipes everything, including the firmware. A USB drive with a new firmware will be needed.
If none of the presets fits your needs, you can start with the closest one and then manually adjust each category to reset or keep it according to your preference.
When printing on the CORE One in compatibility mode using files sliced for the MK4 or other supported printers, the firmware now automatically handles chamber temperature control. Since these G-code files do not contain the required commands for chamber heating or cooling, the printer applies chamber management heuristically. Previously, no chamber control was performed in this mode.
Status messages have been revised to provide clearer feedback during printer operations. They now give more detail about what is happening, show progress where applicable, and remain visible until the operation is completed instead of disappearing after just a few seconds.
NOTE: They also do not disappear when the print is paused, which addresses the issue #3143
Homing behavior on the XL and CORE One has been refined to avoid unnecessary movements. In cases such as filament load or unload, the printer now performs only basic homing, skipping the extra diagonal movements. If a precise position is required later, only the refinement step is executed. For unload operations with auto-retraction, homing is still performed to ensure the correct filament removal angle.
This change applies only to specific situations—G-code G28 without parameters, which is placed at the start of every print, will still trigger a full homing sequence. We are also considering updating slicer profiles in the future to allow optional homing.
In addition, the long and noisy precise homing calibration is no longer run automatically. Instead, the printer now checks reliability and suggests the calibration only when needed, and you can always choose to skip it. If required, the precise homing calibration can be started manually at any time from the Calibrations menu.
The autoload process has been refined to make filament changes faster and easier. Printers now begin preheating the nozzle to 170 °C as soon as the load procedure starts, without waiting for the user to confirm the filament type. On printers equipped with a side filament sensor (CORE One, XL), the procedure also starts automatically when filament is inserted into the sensor. In this case, the toolhead moves to an optimal position for feeding filament through the PTFE tube, and the extruder begins spinning to assist insertion.
NOTE: On the XL, the relevant tool still needs to be selected before autoload is triggered.
Additionally, the printer now checks whether the extruder filament sensor is already active when filament is inserted into the side sensor, warning the user in case debris or leftover filament is present in the printhead.
We have unified the code for chamber filtration between the XL and CORE One, so both printers now share the same features. As a result, the CORE One gains all functionality previously available on the XL, and vice versa.
In addition, several new options have been introduced. You can enable Filter all materials to keep filtration running regardless of filament type, and the Filter usage counter can now be adjusted manually for your own convenience.
We have also added two new G-codes: M147 (set) and M148 (unset), which let you explicitly mark whether a print requires filtration or not, overriding the automatic behavior based on filament parameters. (#4480)
If nozzle cleaning fails, the printer now offers an Ignore option, allowing you to continue with the print instead of being forced to abort the job.
The print sheet detection feature, originally introduced with the CORE One, is now available on MK4 printers. Before starting a print, the printer checks whether a sheet is installed and notifies the user if it is missing.
The firmware now tracks the highest extruding Z position reached during a print and ensures that toolchanges, filament changes, and parking moves are performed above this level. This prevents the toolhead from colliding with already finished parts during sequential printing (complete individual objects).
Gearbox alignment procedure is now available for the XL. We recommend running the procedure in the case that you needed to disassemble and reassemble the extruder.
You can now change filament in any tool from the Tune menu, not just the currently picked one.
Formerly, our printers were only able to control cancelling of the first 64 objects in the print file. This limit has now been increased to 1024.
NOTE: In the printer UI, you will still only see the names of the first 16 objects. The rest will be displayed as “Object X”.
The Wi-Fi icon in the header now displays signal strength, with individual bars lighting up according to the connection quality.
Pressing the knob during a BSOD no longer restarts the printer - it now only silences the beeper. To restart the printer, use the dedicated Restart button.
The evaluation method for the Nextruder filament sensor has been redesigned. This update improves reliability by reducing false runout detections and ensuring that actual runouts are correctly recognized.
Ukrainian language support, first introduced on the CORE One in firmware 6.3.3, is now available across all printers.
Release notes
https://github.com/prusa3d/Prusa-Firmware-Buddy/releases/tag/v6.4.0
Publié : 25/11/2025 6:35 pm
tonyk
(@tonyk)
RE: 6.4.0 Firmware for Prusa XL
Please update the "Home -> Support -> Firmware & Downloads" links as well. If you filter by "XL", it still shows 6.2.6 as of now.
Publié : 30/12/2025 7:43 pm
James Ramsey
(@james-ramsey)
Posted by: @tonyk
That seems to have changed as of yesterday. Given some horror stories I've read (though mainly about the multi-tool XL and the Core Ones), I'm wondering if I should hold off on upgrading.
Publié : 21/01/2026 8:12 pm
tonyk
(@tonyk)
I've had Core 1s on 6.4.0RC for months and an XL single tool on 6.4.0 for three weeks, and they've been fine so far, so ... 🤷‍♂️
Publié : 21/01/2026 8:40 pm
1 personnes ont aimé
Jan Kratochvíl
(@jan-kratochvil)
Membre Admin
Hello.
Based on your feedback and the reports we’ve received, we’ve decided to withdraw firmware version 6.4.0 for the Original Prusa XL. The main issues are related to Phase Stepping calibration.We are currently working on a fix, which should be available in the coming weeks.
If you are experiencing Phase Stepping issues (noise), layer shifts, or random tool crashes, please downgrade to the latest stable firmware version, 6.2.6.
These issues affect only the Original Prusa XL. If you’re running firmware 6.4.0 on your MK4 or CORE One, there is no need to downgrade.
Publié : 05/02/2026 5:43 am
3 personnes ont aimé
Juzam
(@juzam)
Thank you for finally acknowledging this issue and I can't wait for the fix. On the other hand, I've noticed my CoreONE getting noticeably quieter when I rolled back to 6.3.4 and did my phase calibration there.
Posted by: @jan-kratochvil
Hello.
Publié : 05/02/2026 12:28 pm
jan.d.slay
(@jan-d-slay)
I can confirm that!
However, resonance noises from the stepper motors remain—even with 6.3.4.
Publié : 05/02/2026 12:42 pm
bapski
(@bapski)
so what exactly is/are the issue/s. i have been printing ok or have had no problems printing with 6.4.0
so just noise resonance from phase stepping? that's it?
MY MODELS AT PRINTABLES
Publié : 05/02/2026 12:48 pm
jan.d.slay
(@jan-d-slay)
Posted by: @bapski
https://github.com/prusa3d/Prusa-Firmware-Buddy/issues?q=is%3Aissue%20state%3Aopen%20label%3AXL
This is just a quick search result, just what has been labeled.
I can also say this from my own experience. Three days with 6.4.0 were enough to make me revert to 6.2.6.
If you're happy with 6.4.0, then you can count yourself lucky.
Publié : 05/02/2026 12:52 pm
merlinn31
(@merlinn31)
Membre
Wow, only took since September 13th from the first report until public acknowledgement from staff! Almost 6 months.
Hello.
Publié : 05/02/2026 1:21 pm
morreale
(@morreale)
prusa xl noise
Is this what we are talking about here? I am on 6.4.0 and recently built the enclosure and did the pc-cf upgrades to the nextruders.  I decided to also do the upgrades to the cable connections during that upgrade using ASA and the noise coming from the printer during moves is insane.  I thought it was just the new covers rattling so I removed them to test and tightened them mroe. It did go away some but not completely.
I have followed belt tightening guides from Prusa as well as https://investegate.de/prusa-xl-guides/ (including using and validating with the Biqu Belter) I think my homing tower looks pretty good as well. (this was using some older undried Bambu PLA Matte)
Publié : 05/02/2026 3:55 pm
morreale
(@morreale)
downgrading now - will run the same print jsut to see
Publié : 05/02/2026 4:13 pm
morreale
(@morreale)
Downgraded and ran phase stepper calibration.  It is quite a difference (crazy how much louder on video they sound).  Definitely some rattling from the covers.
prusa xl 6.2.6 noise
Publié : 05/02/2026 4:55 pm
morreale
(@morreale)
I am also wondering how much worse the rattling / vibrations are due to the new covers being printed in Prusament ASA vs the original PETG
Posted by: @morreale
Publié : 05/02/2026 4:57 pm
Gertsson
(@gertsson)
Membre
At work we are running 6 XL and now we are getting problems with the printers just waiting for ever on "Absorbing heat" at 0% until a person manually goes to the printer and press "Skip" on the display.
This is a big problem since we run them 24/7 and now we are getting long print queues.  Not had a problem like this before 6.40. We run special buildplates to print without any bed heating so my guess this is related to the issue.
We will have to revert the firmware and see if that helps.
Publié : 06/02/2026 2:45 pm
jan.d.slay
(@jan-d-slay)
Posted by: @gertsson
I print a lot with PCCF, evenly distributed across the entire print area.
If I give the printer the command to preheat the print bed and then immediately send the print job, the bed leveling is poor. If I wait 15 minutes until the 100 degrees in the print bed are evenly distributed, every part is perfect. All surfaces are equally smooth.
You can deactivate Absorb Heat in the GCode. It is better to use the command G4 S900 (900 seconds) as an example. If you have no other problems with firmware 6.4.0, I would adjust the GCode.
See also my signature.
Publié : 06/02/2026 6:31 pm
Gertsson
(@gertsson)
Membre
Posted by: @jan-d-slay
Thanks for the answer, disabling the "Absorb heat" in start gcode would probably work but we rather just go back to the Firmware that was stable for us and is the recommended by Prusa.
Like I wrote we print without bed heating, it's fully disabled (0 degrees) in Slicer, we don't have any problem with leveling or adhesion in it self. But doing this seem to result in a bug in 6.4.0 were the printer tries to run "absorb heat" command and then get stuck at 0% since there is no heat to absorb 🙂 . If bug is still in next Firmware release I will just remove G29 "Absorb heat" in start gcode
Publié : 10/02/2026 3:06 pm
jan.d.slay
(@jan-d-slay)
From my own experience testing versions 6.4.0 and 6.2.6, I know that the Absorb Heat command always worked to deactivate it.
Publié : 10/02/2026 5:36 pm
