6.2.1 Firmware stable for XL
Jan Kratochvíl
(@jan-kratochvil)
Miembro Admin
Summary
  • 'Not HF Nozzle' status reset post-update
  • Recalibration of X and Y Axes after reset
  • Support for M30 G-code
This is the stable release of firmware version 6.2.1 for the Original Prusa MK4S, addressing issues identified in version 6.2.0. This update is recommended for all users.
In firmware 6.2.0, a check was implemented to prevent printing G-codes with high-flow profiles on printers without a high-flow nozzle installed. However, after updating, all nozzles were defaulted to 'not high-flow,' leading to incorrect warnings for many MK4S users.
With firmware 6.2.1, MK4S printers will default to recognizing the nozzle as high-flow. Users can adjust this setting in the printer's menu under Settings.
Reported on GitHub #4401
A bug causing MK4 series printers to lose their homing calibration upon startup has been fixed. This ensures that X and Y axes retain their calibration settings after a reset.
Reported on GitHub #4185
The M30 G-code command, which allows for file deletion from the printer's storage, has been backported from firmware version 6.3.0 to 6.2.1.
Reported on GitHub #4429 and fixed by community contributor @bkerler
Known Issues
Numeric error accumulation possibly causing layer shifts
A recently discovered numeric error accumulation bug may cause layer shifts, particularly on prints using gyroid infill.
A fix is currently being tested and is expected to be released in an upcoming firmware update.
Release notes:  https://github.com/prusa3d/Prusa-Firmware-Buddy/releases/tag/v6.2.1
Respondido : 19/02/2025 6:20 am
