6.0.3 Firmware for Original Prusa XL
Jan Kratochvíl
(@jan-kratochvil)
Miembro Admin
Summary
  • Interim solution of USB disconnect issues (MK4, MK3.9, MK3.5, XL)
  • PINDA off-bed probing repaired (MK3.5)
  • Screenshot procedure fix (MINI)
The developers have thoroughly reviewed the part of the firmware responsible for unexpected USB disconnects, which lead to print interruptions that cannot be resumed. As a quick hotfix, we have added the option to continue printing after this interruption.
However, we will continue to seek a definitive solution to this problem.
Moved bed leveling probing points to avoid probing measurements out of the heatbed area. This issue was reported on GitHub as #3851.
Fixed an issue where the screenshot procedure ended with a blue screen of death (BSOD).
Release notes: https://github.com/prusa3d/Prusa-Firmware-Buddy/releases/tag/v6.0.3
Respondido : 24/06/2024 3:20 pm
tsamisa
(@tsamisa)
RE: 6.0.3 Firmware for Original Prusa XL
Do you know how long a proper fix for the usb problem will be possible? And what was causing the issue? Being able to resume does do something but is far from satisfactory. It means that we have to continuously monitor the print . Also im in the process of ordering the enclosure. As i understand to fully utilize it i have to apply a 6.? firmware. For the time being that is not possible since , as i said before, just resuming every time the usb fails is counterproductive.
Respondido : 24/06/2024 3:54 pm
