3D Pen
martinkh
(@martinkh)
3D Pen
I've been thinking about the issue of watertight joints. Making 2 pieces, one with alignment holes, the other with pins, then designing a "v" joint and then running a bead with the same Prusament I used on the model. Seems like the key is reliable feeding obviously, but also in heating the parent material enough to get it to flow a little before the weldment is laid down. Seems the 3D pens that I am seeing are "Doodle" oriented, not professional products.
Any thoughts on what is out there that works best for PETG, which seems to not be listed? I assume that if one does ABS it should do PETG.
Any chance Prusa is going to make a kick-butt 3D pen more like a plastic MIG welder?
Postato : 20/03/2022 9:39 pm
BMet
 BMet
(@bmet)
RE: 3D Pen
Sigh.
Postato : 21/03/2022 4:20 pm
martinkh
(@martinkh)
RE: 3D Pen
I guess this is the wrong subsection, but I just ordered a 3dsimo multi 4-1
Postato : 22/03/2022 6:56 pm
