Unloading filament when spool is fisnihed
Rafael
(@rafael)
Hi!
My new XL is eating spools like crazy. Normally unloading filament works just fine, except when the spool is finished.
Every time a spool is finished, unloading filament fails. I don't think it has ever worked for me after 5 or 6 spool finished. Is it working for you?
I believe the issue has to do with the side filament sensor. The filament tip cannot go backwards there.
Then there is the problem of removing the remaining filament that goes from the side sensor to the print head. I cannot remove the PTFE tube from either side to access the stuck filament. not form the side sensor or from the head. The only solution I found is to unscrew the part that guides the filament into the print head. Then I can remove the filament and have my print continue OK.
Is that the best way to manually remove the filament?
Is anybody else also experiencing this issues?
Respondido : 31/10/2023 9:28 am
mvikman
(@mvikman)
RE: Unloading filament when spool is fisnihed
You should be able to remove the PTFE tube on the extruder end by pushing the blue collar down and pull the tube out or on the side filament sensor push the black retaining collar towards the sensor housing and pull the tube out.
Respondido : 31/10/2023 11:33 am
I haven't noticed this on my XL (yet) but on my Mk3 I've had similar problems. With some brands (in my case, Jarees) the ends of the filament have a sharp bend, which gets stuck when the printer tries to unload. I got into the habit of watching the spool toward the end and just cutting the filament before it got to that point. (Thankfully, Jarees now has straight ends).
Respondido : 31/10/2023 11:51 am
Rafael
(@rafael)
Thanks, I will experiment.
Respondido : 01/11/2023 9:57 am
Rafael
(@rafael)
I noticed this, even thou It is prusament what I use.
I made a similar plan, but isn't it difficult to access the last bit with some filament remaining?
Respondido : 02/11/2023 6:38 am
Rafael
(@rafael)
yes @mvikman I now managed to easily release the PTFE tubes. On the side I haven't got such a good access as the printer is in a corner.
It is also not trivial to sense if the tube is completely or half inserted.
It may be that the filament sensor on the side fails to allow empty roll remaining out if the PFTE tube is not 100% inserted. Will check later.
In any case, removing the tube is fast an easy, so manual unloading won't be an issue going forward.
Respondido : 02/11/2023 6:43 am
mvikman
(@mvikman)
I measured that when fully seated, the PTFE tube goes 11mm into the extruder connector and 14mm into the side filament sensor.
Respondido : 02/11/2023 10:27 am
1 les gusta
bbrendon
(@bbrendon)
Has anyone figured out a solution so you don't have to disassemble the tubes?
Respondido : 05/07/2025 10:05 pm
Sova
 Sova
(@sova)
Dont run to the end use the first sensor not the secend. If nead to do to the end in my opinion faster way is to open the extruder and use the pliers that came with the printer (heat up before normal procedure like normal filament change ) pull out the filament from the tool and close it and put new filament in like you normaly do.(Sory just red it fuly in that problem the use of only the tool sensor might be beter for you and you will only have a 10 cm max string of filament not 1 m)
Esta publicación ha sido modificada el hace 4 weeks por Sova
Respondido : 10/08/2025 11:24 pm
