Tiny XL wifi cable is driving me nuts
I am trying to connect the tiny wifi connector to the board and I feel like I'm doing something wrong. I've been at it for half an hour and I just can't seem to get it connected. Is there a trick to this?
RE: Tiny XL wifi cable is driving me nuts
Place it directly over the socket and press down quite firmly. It does take a bit of pressure for it to click into place.
Man, that sucked but I finally got it. Thanks.
Here's a tip that has helped me. From the page, "There is a little trick to the installation of the antenna, if you press down hard on it directly, you will find it very difficult to press and your fingers will hurt! The correct way to install the antenna is to put one side of the antenna connector into the connector block first, then press down a little on the other side, and the antenna will be installed." The picture in the link shows the move.
Thanks. What a PITA that was.
