Bumpy surface
John McCauley
(@john-mccauley)
Bumpy surface
Any idea what could be causing this? Almost like the head is too close and damaging what has just been printed. 0.25 nozzle PLA
Opublikowany : 13/05/2024 1:49 pm
That look like a combination of slight warping and not enough infill-support below the upper surface - try adaptive cubic and make sure the first layer is sticking properly.
Opublikowany : 13/05/2024 6:58 pm
RE: Bumpy surface
Looks like pillowing. More top layers and/or more infill.
Opublikowany : 13/05/2024 7:21 pm
John McCauley
(@john-mccauley)
RE: Bumpy surface
The first layer was sticking correctly.
So I increased the temperature by 10, that fixed the issue. Thanks.
Opublikowany : 13/05/2024 9:04 pm
John McCauley
(@john-mccauley)
RE: Bumpy surface
Increasing the temperature did fix it for the test print but not the much larger print. Will try again with the suggestions given.
Opublikowany : 16/05/2024 8:13 am
