1→5 tool upgrade: Filament Sensor Fail on one Tool Head
After doing the upgrade everything calibrated perfectly except for Tool 2 Filament Sensor. It fails before asking to insert filament. I checked that all connections are solid, no wires are pinched, etc.
I was waiting in line for Prusa support, but I need to go to work... I'll try again tonight but wanted to check the hive mind for any other ideas.
RE: 1→5 tool upgrade: Filament Sensor Fail on one Tool Head
Is it the side filament sensor or the sensor in the toolhead? I had the side sensor 2 fail on me after the upgrade. I did hang in until I got someone from Prusa on the line, he made me do a full reset of the firmware, which fixed the problem.
Nope. Tool head.
They work great! You’re missing out by allowing the noisy few dictate your decisions for you.
There is a little access hole right above the nextruder gears. Try blowing some compressed air in there. The ball may be stuck.
https://help.prusa3d.com/article/filament-sensor-mk4-mk3-9-xl_465702
doing a hard reset and reloading firmware seems to have fixed it. All tests successful.
Guys,
can we please keep to the subject matter and the ethos of a support forum,
If a user comment upsets you, could you please move on,
If a comment or subject upsets you a lot, could you please report the post and let the moderators sort it out.
regard Joan
