PrusaSlicer 2.9.5 Filament Edition 1.7.1 - Now With OpenPrintTag Support
I've created a version of PrusaSlicer that allows you to automatically sync filaments with Filament-DB and RFID tags. If you find a bug, please kindly create a github issue in the respective repositories.
The following features are supported:
  • Filaments from Filament-DB automatically show up in PrusaSlicer as User Presets
  • Calibrated parameters are selected based on the current nozzle
  • OpenPrintTag compatible tags can be read with a suitable reader and will select the filament automatically in PrusaSlicer
  • If the spool is weighed and that weight is recorded with the spool, the remaining filament is calculated. When an object is sliced, PrusaSlicer will warn if there is not enough filament available on the spool.
Setup Guide - English
Einrichtungsanleitung - Deutsch (this was machine translated so...)
Posted : 24/05/2026 10:42 pm
4 people liked
Forgot to mention, Filament-DB also supports reading (but not writing) Bambu RFID tags as well.
Posted : 24/05/2026 11:01 pm
3 people liked
