design for Support/Mesh needed
apZ
 apZ
(@apz)
Utenti
I would like to print such a pot, diameter about 60 mm and height about 100 mm and since there is something else on the top surface, it cannot be printed upside down; the walls are 3 mm all around - How can I design the support so that it is supported laterally on the walls - see the support sketched in yellow in the picture - and what should be a solid angle and what are usefull settings for the support? Thank you very much for your support!
Postato : 31/08/2023 2:14 pm
