replacing RAMPS 1.4
Denis Digula
(@denis-digula)
replacing RAMPS 1.4
Hi to all!
My RAMPS board have a bad resettable fuse for a heatbed and it was quicker to buy new RAMPS board instead to order fuse. Would it work if I just put old stepper drivers (and everything else, of course) on a new board, or I will need to program it again?
Thanks!
Denis
Napsal : 09/08/2021 11:50 am
Clemens M.
(@clemens-m)
No programming necessary
Using a Ramps board means - there is an Arduino (for example a 2560 Mega working as microcontroller) ==> if you only change the Ramps board there should no programming of the Arduino board be necessary. Ramps has no own micro-controller.
Best regards, Clemens
Napsal : 19/08/2021 9:45 pm
