Printer won't turn on
yazmin.t
(@yazmin-t)
I recently moved and took my printer apart. When I plugged the cables back in and turned it on I realized that the extruder fans were not turning on and the nuzzle temperature was not rising. I thought they were wrongly connected and swapped two cables between them, then the screen turned off (apparently a short one). Now the motherboard does not turn on but the power center does.
Can any of you give me more information on how to fix it or any information on what may be happening to you?
The errors are:
Extruder fans do not start.
The printer no longer turns on completely.
I am expecting your answers, thanks.
Veröffentlicht : 13/05/2020 9:23 pm
