Printer not printing
Hi, I'm new at 3D printing. I have the "FLSUN 3d printer Prusa i3 diy kit" which I finished putting together, which wasn't toooo bad. I loaded the Repetier software and I'm able to communicate with the printer. I can move head left, right, front, back, up, down. I loaded an image, and I can extrude manually. But it won't print. No error msgs. Can someone help me. Thanks.
Publié : 11/04/2020 7:55 am
RE: Printer not printing
First: That's not a Prusa printer. That's a crappy clone.
No clue about firmware and settings. Maybe you need to tweak something to print over USB.
Usually, you would slice your models on your PC, put the generated gcode file on an SD-card and put the SD-cart into the printer to print something.
Publié : 11/04/2020 8:42 am
