Prusa Mini to equip with camera and Web console to pause/stop print?
[Solved] Prusa Mini to equip with camera and Web console to pause/stop print?
Miroslav Knapovsky
(@miroslav-knapovsky)
Hi Folks,
while having my first 3D printer from Prusa, I'd like to propose a feature.
Print jobs sometimes took ages and having a remote visibility of what's going on and being able to pause/stop the job remotely via printers webpage would be simply great. Is this feature in development? Raspberry Pi camera is a cheap stuff and hopefully can be integrated in future Mini mainboard - https://www.raspberrypi.org/products/camera-module-v2/
Thx
./miro
Best Answer by SamueL:
currently i do not think that this feature exist and will exist. Simply use octoprint. Raspberry pi zero W is cheap.And you can add AI. like Spaghetti detective that watches your print and pauses it when it´s failing. I have 3D printer farm with octoprint and octofarm and it works great!
Posted : 15/02/2021 12:12 pm
SamueL
(@samuel)
RE: Prusa Mini to equip with camera and Web console to pause/stop print?
Posted : 15/02/2021 9:49 pm
Kalimero - Jan Fiala
(@kalimero-jan-fiala)
Jestli potřebuješ tiskárnu dálkově zastavit, zapoj ji přes dálkově (přes internet) ovládanou zásuvku. Přeruš na cca 5 s napájení. Tiskárna se zresetuje a ochlazuje trysku, po cca 10 minutách ji odpoj trvale.
Pokud například musíš odjet z práce a sleduješ tiskárnu webovou kameru, pak je to řešení.
Nejsem zaměstnancem Prusa Research.
Posted : 16/02/2021 12:11 am
Miroslav Knapovsky
@samuel-2
Thanks Samuel - I will give a try. Thanks for the hint. But wouldn't be nice to have at least possibility to pause print with webinterface of printer (well, at least).
@kalimero - I have remotely driven PSU already, but powering off  printer during the print might harm the printer (I guess). Thanks a lot anyway.
./Miro
Posted : 16/02/2021 12:53 am
Předpokládám vypnutí po fatálním selhání tisku, kdy se pokazit už nic nedá, naopak. Je však potřeba hned tiskárnu zas zapnout, aby ventilátorek ochladil hotend a teplota nenastoupala nahoru.
Posted : 16/02/2021 3:35 pm
Miroslav Knapovsky
Diky za radu. Zkusim ten octoprint. Uz jsem si dal dokupy Raspi a kameru, tak jen najit cas.
./mira
Posted : 16/02/2021 3:46 pm
