What is "Set Ready" and when should it be used?
tg73
 tg73
(@tg73)
Utenti
I've tried searching the Prusa KB, I've tried googling, I've tried searching the forum - but I can't find documentation explaining what "Set Ready" does and when it should be used - both the button in the Prusa Connect UI and in the LCD menu on a printer (in my case, an XL). Can someone point me at the documentation and/or explain? Thanks!
Best Answer by JP Guitars:
It tells Prusa Connect that the printer is ready to go. The next job in the queue will then start printing, or if there is nothing in the queue when you add something to the queue it will immediately start printing
Postato : 09/12/2023 1:10 pm
JP Guitars
(@jp-guitars)
RE: What is "Set Ready" and when should it be used?
Postato : 09/12/2023 1:16 pm
Tojik e tg73 hanno apprezzato
