                    Strona 4 / 4
                         Wstecz
Login credentials to Prusa Link are not he same as the one on Prusa Connect.
They are available when you look in the menu options in the printer itself, if I remember correctly username is 'maker' and the password depends on the printer as it is generated based on printer serial number. The password is actually named as API Key in the menu.
Also see but notice differences between local connection vs Prusa Connect
                            Opublikowany : 23/02/2025 6:57 am
                    RE: Troubleshooting
thank you
                            Opublikowany : 24/02/2025 12:51 am
                    Strona 4 / 4
                         Wstecz
