Login credentials to Prusa Link are not he same as the one on Prusa Connect.
They are available when you look in the menu options in the printer itself, if I remember correctly username is 'maker' and the password depends on the printer as it is generated based on printer serial number. The password is actually named as API Key in the menu.
Also see but notice differences between local connection vs Prusa Connect
RE: Troubleshooting
thank you
RE: Troubleshooting
Hello I have problem with my Prusalink...
I tried multiple times to connect to my home WiFi, Hotspot on my phone, Hotspot on my PC. And nothing worked... The LCD screen always says ,,No LAN access". I bought new microSD card and still nothing. Tried adding wpa_supplicant.conf still nothing. Tried support nothing. I´m using RPi zero W with GPIO. And yes i checked the SSID and password multiple times and flashed the microSD card multiple times. Can someone help me please? I´m really desperate.
