Trouble Shooting Prusa Link
Page 3 / 3
Tojik
(@tojik)
Membre Moderator
RE: Trouble Shooting Prusa Link
Hi, sorry for my silence. I was at formnext, then it was a national holiday, then I took on a weekend project that took me to this day to complete. I have some trouble understanding you too, so I'll just write out what I think is happening and you can confirm, or tell me more about each one.
You either can connect to PrusaConnect, or you can connect to PrusaLink and it cannot get to the internet? In which state is it now?
How do you get to the state, where it sees only Connect? It needs to be configured first and that's done on LAN, so you have to see it on the lan to get it to use Connect.
If it says bad api key, try to swith to digest authentication and use that, PrusaSlicer has the option to do that.
Again, sorry for being slow on this.
Publié : 21/11/2022 10:43 am
Patrick.b
(@patrick-b)
Hey Tojik
oh really if you have time , like to know more about formnext ..i went there last time was so great i met Jo at the booth ...i miss formext this year sad... 😓 .like to see the news and get sample to test ...
well so far and really never mind for ur late answer, but during this days i tried many diff options , i user explain and i test the prvious ver of Raspi the im 1.6.2 then old prusalink too , that works but sometime the link doesn't connect .and the display link is not so useful than the 0.7rc so i did same but last ver of prusalink ..
as now all is working well , just i have to shut down the printer then run again as the 1st time i put on , wait...then prusconnect show very well each time that seems very stable but the link sometime not , only if i shut of and on the mk3s then ok ..
so I just test the digest right now and put user + password then work too .. let's see further ..but when i wait a little time that the printer find the wifi and the link then all seems working well...
just have to be improved , adding more quick button in prusalink and some other option that would be great..
thx
Publié : 21/11/2022 11:01 am
Tojik
(@tojik)
Membre Moderator
Idk, I found the exhibition kinda boring. It's not the bleeding edge of what's possible, it's old concepts remixed into functional products or prototypes. The trip was absolutely amazing, thanks to prusa and the guys working there. The exhibition not so much. A lot of business people there.
Publié : 21/11/2022 1:23 pm
Patrick.b
(@patrick-b)
😎 😱  you almost make my day 😉 as i miss it, but then after reading your comment it seems the same as the 3Dprint at Lyon.. lot of business and some new material idea, glass print ....but then not to exciting, the good point is 3dprint is free...as all or almost big exhibition in France ......
Publié : 21/11/2022 3:03 pm
Patrick.b
(@patrick-b)
Hi Tojik ,
just to inform you and asking that i have to reboot but not even reboot but shut down the printer and run again then the link is opening ..again the connect work well fast but the link even i wait few minute that wifi ok and my pc too ( i only use with cable rj45) is fine but then when i shut and start again the mk3 the link is running !!
any idea or ? thx
Publié : 22/11/2022 8:53 am
Tojik
(@tojik)
Membre Moderator
I don't know what it is, you're trying to tell me.
Reboot on the RC1 is broken, so yes, you need to shut it down by turning off the printer.
I guess try to tell me in your native language what the problem is. I'll try to get a person to translate.
You basically told me that everything works well and fast and that PrusaLink is running. But it looks like that's definitely not what you meant.
Publié : 22/11/2022 12:40 pm
Patrick.b
(@patrick-b)
okayyy sorry i did write fast, so yes all is working fine as well as the slicer now with the digest A is ok ..just the prusa link is not work or appears the 1st time i want to link with it ! i need to shut down the printer once more then run again, and the link appears on my mozilla ..if i reset mk3 nope same, if i stop and restart yes !! not too bad but wierd !!
maybe easier to read it  now 😉
Publié : 22/11/2022 3:17 pm
Jan
 Jan
(@jan-14)
my prusalink just stopped working, i am on the latest update on mk3s 3.12.2 and on rpi 0.7.0rc3. On the printer screen I can read "Starting PrusaLink".
While I am pinging this IP I am getting responses but only there. On this IP in the web browser there is no response, also on connect.prusa3d.com. I was trying resetting, looking if there maybe thiassamble but everything is looking great.
Format SD?
Publié : 12/05/2023 6:26 pm
Tojik
(@tojik)
Membre Moderator
Hi, I have never seen PrusaLink just stop working except because of a corrupted or dead SD card. I would suggest an industrial card. 8 GB is fine, you can go bigger if you want. So far they work great.
Publié : 12/05/2023 6:31 pm
John Smith
(@john-smith-4)
Yes, I just downloaded everything today and I had the same problems with the bad API Key.
Strange. I think this is a bonefide bug.
However, I switched to HTTP DIGEST and everything worked correctly.
  • prusalink-0.7.2.img.xz (running on RPi 3B+)
  • Windows 11 Pro 22H2  (PrusaSlicer 2.6.1)  and also tried    (PrusaSlicer 2.7.0-alpha1 )
  • firmware 3.13.1-6876 (running on i3Mk3 converted to i3Mk3s)
Sincerely,
-N
Publié : 01/11/2023 9:02 pm
Tojik
(@tojik)
Membre Moderator
Hi, no clue what "bonefide" means, chatgpt thinks it could be "bona fide" - latin
By default, PrusaLink does not generate its api key, you would have to generate it in its settings tab. If you did not do that, you were probably trying to use the PrusaConnect api key which would not work
However, if you generated and copied the api key and it still did not work, then it really might be a bug
Publié : 02/11/2023 9:56 am
Page 3 / 3
