Setting up Notifications with Telegram and Prusa Connect.
[Resuelto] Setting up Notifications with Telegram and Prusa Connect.
Tom Lenor
(@tom-lenor)
I would like to get notified on Telegram when a print has finished or a problem has occured. The Settings page mentions " Instructions on how to do this are in the Channels setup section." I am not able to locate this "Channels setup section". Can someone link the docs?
Best Answer by Tojik:
I've attempted to provide something to go off over here: https://forum.prusa3d.com/forum/postid/632290/
I unfortunately don't know where are the official guides, but hope you'll find this helpfull
Respondido : 17/02/2023 4:29 pm
Tojik
(@tojik)
Miembro Moderator
RE: Setting up Notifications with Telegram and Prusa Connect.
Respondido : 17/02/2023 4:51 pm
Tom Lenor
(@tom-lenor)
That's a great starting point. I can't get it to work though. I know that my bot is working since  https://api.telegram.org/bot+toke/getUpdates returns true but replacing  /getUpdates with /sendMessage shows as invalid end point. do I have to configure bot commands as well?
Esta publicación ha sido modificada el hace 3 years por Tom Lenor
Respondido : 17/02/2023 11:55 pm
Tom Lenor
(@tom-lenor)
After trial and error and endless googling I found the issue. One needs to have a username in telegram for the api to work. Since I have created my telegram account years ago and barely used it, i had yet to set it up.
Respondido : 18/02/2023 12:16 am
Tojik
(@tojik)
Miembro Moderator
Wow, okay, I'll note that and I'll try to check the guide if I remember. Thank you
Respondido : 18/02/2023 1:05 am
MIKE2003
(@mike2003)
I did install discord, it works perfectly!!!
Respondido : 25/02/2023 10:14 pm
Fred
 Fred
(@fred-7)
Miembro
Comment faire les réglages DISCORD?
Merci pour votre aide
Respondido : 02/03/2023 8:44 am
Rene Prettenthaler
(@rene-prettenthaler)
Hi.
I have read that you setup for discord messages from Prusa Connect.
Can you give me instruction.
Thanks.
Respondido : 04/06/2023 4:48 pm
Tojik
(@tojik)
Miembro Moderator
Hi, you can find them here: https://forum.prusa3d.com/forum/postid/640679/
Hope everything goes smoothly 🙂
Respondido : 05/06/2023 12:55 pm
Martin G
(@martin-g)
Miembro
Hi I an´t find setup for Telegram, only for discord. THX
Respondido : 09/08/2023 7:36 pm
Tojik
(@tojik)
Miembro Moderator
Please click on the link in the accepted answer. That will take you to the (sort of a) guide
Respondido : 10/08/2023 11:43 am
