raspberry pi zero wh also ok?
Caveman
(@caveman-2)
Miembro
can't find zero w anymore so my question is will a zero wh also work?
Respondido : 03/09/2021 8:55 am
Nox
 Nox
(@nox)
Miembro
Yes, but
AFAIK, that's just a standard Raspberry Pi Zero W with soldered on header pins. So you can use it, but you'd have to desolder the header pins first.
Respondido : 03/09/2021 12:39 pm
1 les gusta
Caveman
(@caveman-2)
Miembro
Found w
Found a supplier that still had 2 w in stock and got those overnight to me.
Respondido : 03/09/2021 5:07 pm
2 les gusta
Did they also have unobtanium in stock too?
I can't find the Pi Zero W in the UK...  at least not at reasonable costs!  🙂 I'm a cheapskate
Respondido : 16/09/2021 11:39 pm
House3D
(@house3d)
Miembro
Yes
I am also in the UK and could only find the Pi Zero WH. I de-soldered the existing header pins and replaced with 18mm pins. Works perfectly fine.
Respondido : 25/09/2021 3:31 pm
excellent
where did you source your Pi?
I got one from the PiHut
Respondido : 25/09/2021 4:26 pm
House3D
(@house3d)
Miembro
Pihut
Got mine from the PiHut too!
Respondido : 25/09/2021 4:35 pm
Unfortunately,
At the moment we are suffering Internet hell.
we are on our fourth router... awaiting our fifth router...
we are getting disco light type displays off the router, huge numbers of disconnects and next to no download speed...   less that 750Kbps
Upload speed is no problem 16+ Mbps...
the engineer reckoned the line to the house was delivering 75MB/s download... he disconnected everything bar the router and an ethernet PC and still we were seeing next to no download data capacity.
we then tried a laptop via wireless,  and that was trash too. the wireless laptop works fine on my Mobile data hotspot...
there has been little opportunity to sort the RasPi... so far... 🙁
the computers were a Ryzen Gaming PC, and an Intel i7 machine with a good spec
so it's not likely to be a lack of processing power
think I'll play with my Arduino's for a while
Respondido : 25/09/2021 4:43 pm
Small world!
Joan
Respondido : 25/09/2021 4:45 pm
DocPO
(@docpo)
Miembro
RE: raspberry pi zero wh also ok?
What about the raspberry pi 2 w ? Is that compatible?
Respondido : 23/12/2021 6:51 pm
DanielAttia
(@danielattia)
Miembro
The RasPi Zero 2 W is a drop-in replacement for the older Zero W.
Posted by: @docpo
Respondido : 23/12/2021 7:10 pm
tentaclejoe
(@tentaclejoe)
Miembro
Where did you guys find 18mm headers? I'm in the US and can only find 19mm or 20mm. Did you just cut yours?
Respondido : 23/12/2021 10:40 pm
Neolker
(@neolker)
Miembro
Digi-Key
Respondido : 24/12/2021 12:20 am
Win J.
(@win-j)
Miembro
Do you have a part #?
Respondido : 25/12/2021 5:47 am
1 les gusta
DanielAttia
(@danielattia)
Miembro
https://www.digikey.com/en/products/detail/sparkfun-electronics/PRT-14275/7428264
Posted by: @win-j
Respondido : 25/12/2021 6:12 pm
DanielAttia
(@danielattia)
Miembro
Usually, retailers that usually sell Raspberry Pi's usually also sell the associated accessories...
https://www.sparkfun.com/products/14275
https://www.adafruit.com/product/2822
https://www.canakit.com/pi-zero-gpio-header.html
https://vilros.com/products/20-pin-gpio-solderless-hammer-in-header
Respondido : 25/12/2021 6:20 pm
DocPO
(@docpo)
Miembro
I just bought 20mm and cut them down after soldering it.  Super easy.
-PO
Respondido : 19/02/2022 4:56 pm
