PrusaLink 0.7.0 final
Jakub Dolezal
(@jakub-dolezal)
Member Admin
just a reminder for all the PrusaLink users. The version 0.7.0, released in May, has reached a final stable version, with the following changes:
  • Fixed printer sends info about api key change to Connect after change
  • Added the network error beep setting to the web API
  • Support renaming G-codes directory (cfg and API)
  • Disable error beeps during prints
  • Static Web update
    • Using v1 endpoints for job and transfer
    • Creating and Deleting folders
    • Translation update
    • Network error chime control
    • Default storage names
    • Upgrade procedure rework
GitHub release and download link: https://github.com/prusa3d/Prusa-Link/releases/tag/0.7.0
Assembly manuals
/ Knowledge Base
Posted : 18/08/2023 8:14 am
Byron
(@byron-3)
RE: PrusaLink 0.7.0 final
Hi Im still on 0.6 is there an easy way to upgrade without reflashing ?
Posted : 22/08/2023 6:31 am
Jakub Dolezal
(@jakub-dolezal)
Member Admin
Hi Byron,
PrusaLink update without removing the MicroSD is possible starting version 0.7.0, therefore if you are running an older version you have to unfortunately remove it from the printer.
Assembly manuals
/ Knowledge Base
Posted : 23/08/2023 7:12 am
mikrom
(@mikrom)
I am running v 0.7.0 and if I check for an update it returns: "PrusaLink → The package is up to date", but there is a 0.7.1.rc1 on the GitHub. Is there a way how to do an online update?
Posted : 30/08/2023 5:11 pm
Tojik
(@tojik)
Member Moderator
Hi, sorry, no, there is no option to d
switch to like a beta tester branch in the updater. Might be a good idea to add it tho
Posted : 30/08/2023 7:33 pm
Jeremi
 Jeremi
(@Jeremi)
Guest
i've installed the prusalink and updated firmware on printer prusa i3 mk3, with 3.13, and when loading web broswer to log into the prusalink it say my printer firmware is out of date, and when i re-go check into printer settings it tells me it has the 3.13 any idea ?
Posted : 05/09/2023 7:40 pm
Tojik
(@tojik)
Member Moderator
Hi, are you using the MMU?
If not, how is your Printer connected? USB or GPIO pins?
The error is probably a fluke created by the way error codes are done in PrusaLink.
Sorry about that
Posted : 05/09/2023 8:08 pm
Jeremi Comeau
(@jeremi-comeau)
its connected GPIO pins, and no mmu
Posted : 05/09/2023 8:11 pm
Xtsoccom
(@xtsoccom)
can someone point me to the instructions how to flash 0.7.0? I can't remember how I did it back on 0.6.1.
I am on a MK3S+
This post was modified 2 years ago by Xtsoccom
Posted : 22/09/2023 3:10 am
Xtsoccom
(@xtsoccom)
Do I have to flash it with PI Imager?
Posted : 22/09/2023 3:24 am
